03-15-2022 04:47
03-15-2022 04:47
I am a server in a restaurant, at the end of my shift most of my steps are showing as swim. How do I fix this 😞
03-15-2022 04:54
03-15-2022 04:54
Hello @63TMKK
If you go into the App on your phone, tap on Exercise, then the cog icon at the top right corner of the screen, it brings up auto recognized activities. Tap on Swim, turn it off and then tap Done to save it.
Sync your Charge 5.
Hopefully that should switch it off for you.
I hope that helps a bit.
03-15-2022 04:54
03-15-2022 04:54
Hello @63TMKK
Sync your Charge 5.
03-15-2022 05:05
03-15-2022 05:05
Thanks, I will see if this works today. 🙂
03-15-2022 05:23
03-15-2022 05:23
Good luck! I really hope it works for you!
