04-03-2024
13:05
07:30
EstuardoFitbit
04-03-2024
13:05
07:30
EstuardoFitbit
My watching facing is hanging on by the carbon ribbon underneath. I have had a Charge 5 for a year. I am only getting a years wear out my watches. I wish there was a place to repair the watch. If not it's time to buy a new one.
Best AnswerHi @Gg_ginabina there are no repairs for these devices, but I think there is something you might be able to use to keep your Charge 5 working for you. On Amazon, search for "protective band cover for Charge 5" and see what pops up. There is a band which takes the pebble portion and completely encompasses it, so it can be used. Some people have used it as a remedy for the broken tabs on the pebble which made it impossible to use a regular band. It might help you to continue using your device. Most are priced under $20.
Thank you for your response, I saw it days ago, but hadn't responded. I will check it out on Amazon. ❤️🙏💪
