10-12-2022
08:35
10:52
DavideFitbit
10-12-2022
08:35
10:52
DavideFitbit
Hi
I only brought my Fitbit Charge 5 in January 2022 and have always been very careful around water with it. I tried to use it the first time when swimming and it seems to have got damaged. I was only in the water for a very short period of time and the watch wasn't submerged more than a few feet. It now won't turn on, charge and just has a black screen. I have tried leaving it in rice too. Is this covered in the warranty as I have had it less than a year ?
05-12-2023 01:44
05-12-2023 01:44
Best Answer05-12-2023 05:27
05-12-2023 05:27
I was interested to see the difference between waterproof watches and water resistant watches. On one of the websites I looked at it said there was really no such thing as a waterproof watch just water resistant to different deaths. It stated that if your watch was rated to 50 m it was safe to use Under a shower, and from what I have read, Fitbit does not recommend using it in the shower because of the chemicals and soap that might cause the seal that protects the inside of the Fitbit from deteriorating. It stated that a watch rated for 100 m was good for swimming but not for diving. It appears that prolonged immersion of a device rated for 50 m would not be recommended. Based on what I have read, I would not deliberately placed my Fitbit in the water for fear that it might fail, and I would be throwing away good money,
Best Answer05-12-2023 05:43
05-12-2023 05:43
I too have had the same experience as Evisbr. Help.
Best Answer05-14-2023 17:49
05-14-2023 17:49
Bingo! I went into the pool yesterday as I always do wearing my charge5. Never had a problem in the past but this time it went black bc the battery was dead. Charged it to 99%. Depleted within an hour. Then X with a red circle. Then I realized that the red light in the back of the device stays on and that is why the battery dies. I also deleted the device and reinstalled a new one. Same problem. Out of warranty and offered a 35% discount. Don’t know that I’m going to replace it. According to the Fitbit specifications the device should be water resistant. It obviously is defective if water can get into it.
01:08
09:01
DavideFitbit
05-15-2023
01:08
09:01
DavideFitbit
Fitbit customer service gave me very good service when it happened to
me.They provided me with a replacement which they didn't need to as it was
out of warranty.
I just told them exactly what happened.
Best Answer05-15-2023 11:37
05-15-2023 11:37
I've got the same issue as the OP. I've worn my Charge 5 daily for nearly six months since new with no problems. Yesterday I wore it in a swimming pool for the first time, only in the water for about 15 minutes, and it hasn't worked since. The water seems to have killed the battery and/or the charging function. The last sync reported 'battery empty'. When I plug in the charging cable the device vibrates and displays the Fitbit logo briefly but won't do anything else. The reset procedure using the button on the charging cable does nothing. As others have said, this is hopeless for a device supposedly designed to track swimming activity. I need a fix or a replacement, please.
05-15-2023 15:47
05-15-2023 15:47
SEE YA FITBIT! Offered me a 35% discount as a customer since 11/2014 and owning my charge 5 only 1 year, 5 months! Millions of posts on the same issue. Obviously there's a problem. Good luck everyone 🤔😪🙃
05-15-2023 16:29
05-15-2023 16:29
Best Answer05-16-2023 02:24
05-16-2023 02:24
Best Answer06-12-2023 15:39
06-12-2023 15:39
I've now had (2) Charge 5's die after their 1st entry into swimming pool. First time I knew I was taking it in, 2nd time was an accident/forgot about it. Both times, same result. ... screen black, might charge but discharges rapidly. A fried device.
Best Answer06-15-2023 10:57
06-15-2023 10:57
Had my Charge 5 for just over 12 months and took it swimming for the first time on the weekend. Got out of the pool and it wasn't working. Put it in rice for 3 days, nothing happening. Contacted Fitbit support and got the run around and their response was a 35% discount on another device. Never been in the shower, never near the water but thought I would try it for lap swimming. Not happy at all. Won't be purchasing anything Fitbit related if that's how they treat their customers.
06-15-2023 12:04
06-15-2023 12:04
