06-26-2023 11:52
06-26-2023 11:52
I've recently gotten the Charge 5 in order to participate in a study, so I need to wear it pretty much all the time. The problem is I also need to wear wrist braces at night due to possible carpel tunnel in each hand.
Can I wear the tracker under the brace if I keep it loose enough to avoid too much pressure on the tracker, but tight enough to keep my wrist from bending?
Best Answer06-26-2023 12:50
06-26-2023 12:50
Hi @PurpleDucky
At first glance, I don't see an issue with wearing your Charge 5 under your wrist brace at night as you described. It seems that your device should still be able to track your data. If you need to adjust the sensitivity, click here for instructions: Fitbit sleep tracking & sensitivity
06-26-2023 12:50
06-26-2023 12:50
Hi @PurpleDucky
06-26-2023 13:11
06-26-2023 13:11
Thank you. I will give it a try. I love seeing my sleep patterns, but I don't like the buzzy fingers and numbness if I don't wear the brace. So fingers crossed that this will work 🙂
