03-19-2022 02:48
03-19-2022 02:48
My daughter (whilst exercising) has damaged the sprung loaded clip that holds the strap on her Charge 5.
can someone point me in the direction as to where I can get a replacement or are there any straps that I can buy that does not use this clip??
03-19-2022 02:54
03-19-2022 02:54
Hello @Murphyjo1968
I'm sorry to hear about that. As far as I know, you can't get replacement clips but you can get straps that completely enclose the pebble part.
I'm not sure where you're based, but here's a link to an example on Amazon.com. I searched for rugged case. There are other brands, colors and designs.
I hope that helps you a bit.
