01-05-2022 10:59
01-05-2022 10:59
I'll spend hours on the slopes but I don't see this activity reflected on my Charge 5.
Where is it?
TIA
Best Answer01-05-2022 11:14
01-05-2022 11:14
Hello @fhp911
Skiing is not automatically recognized by your Charge 5, so you have to use a workaround.
If you go into the App on your phone, tap your profile picture then Charge 5, then Exercise Shortcuts, you can choose one you don’t use by swiping left to delete it.
Then choose a new one by tapping +Exercise Shortcuts- either Workout or Outdoor Workout would be good choices. Sync your Charge 5 and it should show up under Exercise.
When you’re getting ready to start your skiing session, press Start and then End when you’ve finished.
Later when you go into the App you can edit the exercise name by tapping on the white arrow to the top right of Categorize Exercise. Start typing in the Search box and you’ll find Skiing as an option. Select.
I hope that helps you a bit.
01-05-2022 11:14
01-05-2022 11:14
Hello @fhp911
01-05-2022 11:19
01-05-2022 11:19
