10-16-2023 05:17
10-16-2023 05:17
I'm unhappy that my Charge 5 died (doesn't read HR) 13 months after purchase, with no more warranty protection.
But after researching Garmin and Oura, I would consider buying another Fitbit. Mostly because sleep tracking was pretty good, and the price is low.
So, is there a Fitbit device you would recommend, other than the charge 5, with decent sleep and activity tracking?
Other budget options also welcome, thanks.
10-16-2023 08:06
10-16-2023 08:06
Hi there @nanami04, welcome to the Fitbit Community.
It is nice to see you are interesting in getting a new Fitbit device.
Please keep in mind that all of our Fitbit devices can track your sleep in addition to a variety of other features. If you are not sure what to buy, I recommend you take this test, which will help you identify the choice that best meets your needs.
10-16-2023 08:51
10-16-2023 08:51
Regardless of your decision, it may be worth contacting Fitbit support even if your device is out of warranty. If troubleshooting doesn't resolve the issue, you may get a discount offer off a new device.
On your underlying question, my Fitbit 5 just started acting up (freeze with black screen, no response or tracking until it was plugged into a charger) and I am getting a Fitbit Charge 6 as the closest replacement. Hopefully it ends up being more reliable than the Charge 5. I find it interesting that so many Fitbit 5's seem to be failing or glitching after the latest Fitbit app update and right as the Charge 6 launched.
