04-27-2023
12:16
12:42
EstuardoFitbit
04-27-2023
12:16
12:42
EstuardoFitbit
I have Charge 5 Fitbit. It won’t sync with my iPhone unless I do it manually, and sometimes trying to sync manually won’t work either.
Is there a way to fix this?
Moderator edit: format
07:56
06:47
04-28-2023
07:56
06:47
Hi, it's good to see you around the Fitbit Community for the fist time, @SparkleSias.
Thanks for the details provided about your experience when syncing the Charge 5.
Let me share that the All-Day Sync function has been removed from the Fitbit app on both iOS and Android. However, your data will now automatically sync each time you open the Fitbit app when your Fitbit device is nearby. However, if you're having other syncing issues, I'd recommend trying the steps described in this help article as well.
In addition, make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
