05-01-2023
20:12
08:10
DavideFitbit
05-01-2023
20:12
08:10
DavideFitbit
I’ve tried all the recommended fixes (charging fully, disabling tracking features I don’t use, restarting, and I’ve never had the display “always on”, software was all up to date according to my app, and I even tried a factory reset; nothing worked. Now my Charge 5 is dying as soon as it’s disconnected from the charger. If I plug it back in it shows the Fitbit logo and starts charging from 1% again. It doesn’t matter how long it was previously charging or what % the battery was at when disconnected. I called the support number and was told to keep trying for a couple days before calling back, pretty sure that was not helpful advice at all!
07-30-2023 17:00
07-30-2023 17:00
09-06-2023 08:12 - edited 09-06-2023 08:14
Hi everyone, thank you for confirming that you've been having similar issues with your Charge 5. I'm sorry to see that you're still having these problems.
If the device is not responding or not charging, please make sure to exhaust all the troubleshooting options shared here earlier. In case the battery is draining faster than usual. Please follow the standard troubleshooting steps in this article as well.
If you continue to experience any of the same issues, please make sure to get in touch with the Customer Support team so they can let you know about the options available for you.
Best Answer09-06-2023 12:52
09-06-2023 12:52
Best Answer09-12-2023 07:20
09-12-2023 07:20
@Ragnar77 I'm sorry to see that it wasn't possible to receive a replacement.
Thanks for taking the time to share your feedback about the device and Customer Service. The team continues to work to improve the quality of products and services and your feedback is an important part of that process.
