11-29-2021
20:13
10:43
DavideFitbit
11-29-2021
20:13
10:43
DavideFitbit
I'm so over the problems with the Charge 5, wouldn't sync all day. restarted phone, Charge 5, unpaired now my phone won't pair with Charge 5, just saying failed to connect to Charge 5, check for the issue and try again. If only I knew what the issue was?
11-30-2021 10:42 - edited 11-30-2021 10:42
Hi, thank you for sharing this information about the inconvenience that you're experiencing with the Charge 5 and the troubleshooting steps that you already tried, @SunsetRunner.
Before considering other options, since you already tried the restart procedure, please follow all the recommendations listed in this article to resolve problems during the set up process. This has been useful for other users experiencing something similar as well.
In addition, make sure to check the compatibility requirements listed here. Keep in mind that it's necessary to have Apple iOS 13 or higher, and Android OS 8.0 or higher.
Thank you for taking the time to share your feedback about this as well.
Hope this helps, I'll be around.
Best Answer11-30-2021 10:42 - edited 11-30-2021 10:42
Best Answer11-30-2021 17:22
11-30-2021 17:22
It's fixed, by turning the phone and watch off and on several times, disconnecting charge 5 from my phone turning both off/on again then reinstalling.
Have no idea what fixed it but it's fixed.
12-09-2021 07:24
12-09-2021 12:11
12-09-2021 12:11
Best solution -
Remove your Charge 5 from your FitBit account
Uninstall FitBit app from your phone
Unpair Charge 5 from your phone in BlueTooth
Clear user data in Charge 5
Restart your phone
Take another phone
Install FitBit app
Create FitBit account with another email adress
Add your cleaned Charge 5 to this new account
Update firmware of Charge 5
Remove Charge 5 from this "new account"
Take your former phone
Install FitBit app
Log in to your former account
Add Charge 5
Done
12-17-2021 13:45
