04-18-2023
15:49
09:20
AndreaFitbit
04-18-2023
15:49
09:20
AndreaFitbit
Help! Is zone minutes on the device the same as active zone minutes? Thanks DJR111
Moderator Edit: updated subject for clarity.
04-18-2023 20:56 - edited 04-19-2023 08:06
@DJR111 wrote:Help! Is zone minutes on the device the same as active zone minutes? Thanks DJR111
Yes, same thing, just shortened name by leaving leading "active" off.
But totally different from older "Active Minutes", so leaving "active" part off helps to clarify that also, to just think of it as "zone minutes" without the "active" part.
Or you also often see it as AZM for Active Zone Minutes.
04-19-2023 02:56
04-19-2023 02:56
Welcome to the Fitbit community, @DJR111!
Adding to what @JohnnyRow already has mentioned you might want to have a closer look here to get more insight on this topic:
What are Active Zone Minutes or active minutes on my Fitbit device?
