12-30-2022
07:11
03:30
12-30-2022
07:11
03:30
Hi all, I got a charge 5 from santa having previously used another brand of tracker. Im so frustrated, my app doesnt show wifi settings on the watch tile, it just keeps saying oops no Internet connection. Ive tried all the suggestions i can find but nothing is working, id like to change my watch face but it simply wont let me connect the tracker to the internet.. any suggestions before i pull my hair out! thanks
12-31-2022 03:30
12-31-2022 03:30
Hi there, @divechick. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Charge 5 before reaching out. @Aquahonoredhi Thank you so much for your help!
The "Oops no internet connection" issue can be caused by the use of the following on your phone:
Hope this helps.
12-30-2022 15:47 - edited 12-30-2022 15:49
To change the clock face, you must use the Fitbit app on a device already connected to the Internet. You are not able to change the clock face from the watch itself.
12-30-2022 23:40
12-30-2022 23:40
yes, but i cant get the watch to show me the wifi settings on the app to connect the watch
12-31-2022 03:30
12-31-2022 03:30
Hope this helps.
01-01-2023 07:00
01-01-2023 07:00
thanks i will look into that. and get back to you if im successful.
01-01-2023 07:11
01-01-2023 07:11
FANTASTIC! turned off my private DNS it all worked... got face changed.. brilliant thankyou.. was about to return my watch to the shop... yay.. sorted.
