11-24-2023 15:06
11-24-2023 15:06
When Charge 5 came out, I upgraded from my Charge 4. I really like the Fitbit alarm feature since I am pretty deaf at night with out my hearing aids. The Charge 4 was very efficient at waking me up. The charge 5 was not good. I assume it has the same vibrator in a much larger tracker, hence the felt vibration was less and I sleep through it. I put the 5 in the drawer and returned to the 4. My question is: Is the vibration system in the charge 6 much better than the 5 and at least as good as the 4. The 6 case appears to be slightly larger than the 5.
Best Answer11-24-2023 20:07
11-24-2023 20:07
Hi @teebox12too - did you know if you are unhappy with the watch Fitbit have a 45 day refund policy or possibly authorised dealers too, some stores provide 14 to 30 day refunds.
The same happened with Versa vibrations which worked fine but later models have much weaker vibration, possibly to make the battery last longer which is inverse logic as the vibration goes on longer as you don't feel it and therefore can use more battery as well as being ineffective.
