06-06-2025
13:31
06:39
DavidFitbit
06-06-2025
13:31
06:39
DavidFitbit
I would like to be able to see HR and distance at the same time while running? Is that possible? Now I have to tap my screen the entire time..
Best Answer06-07-2025 09:57
Silver Fitbit Product Experts share support knowledge on the forums and advocate for the betterment of Fitbit products and services. Learn more
06-07-2025 09:57
@Lezzeliej You can have the screen-wake display always on. Pull down from the clock face, under settings, enable always-on. However, I don't think it's possible due to the screen size limitation and the current set up of the software's user interface to display 2 data points at the same time. I'm with you there about seeing a specific stat all the time. I like seeing my pace but unfortunately, need to toggle through the whole series of stats if I fat-fingered the tap while jogging.
