01-19-2024 05:21
01-19-2024 05:21
Steps, sleep, and others not syncing to Apple phone. I want to discontinue Premium as not getting my money's worth any more.
01-21-2024 09:35
01-21-2024 09:35
I have restarted Charge 6, iPhone, and reinstalled app. Still not working! I am disgusted.
01-21-2024 09:55
01-21-2024 09:55
I don't have an iPhone so I can't help. Not sure how new you are to Fibit. Was it working and then it stopped, or did it never sync? When I first had an issue and couldn't figure it out, I called Fitbit support and they helped me figure out my issue. Good luck.
Best Answer01-21-2024 10:31
01-21-2024 10:31
Best Answer01-23-2024 13:27
01-23-2024 13:27
I’m having the same issue. Anything get it to work?
01-23-2024 15:25
01-23-2024 15:25
Best Answer01-23-2024 16:10
01-23-2024 16:10
Totally in the same situation. So frustrating that my charge3 worked so well and now with the 6 nothing is easy. Syncing the device is a challenge. It works randomly. And when nothing happen I usually need to restat my phone (iphone) and or reset the charge6.
So disappointed with that new device. Does not count floor (my old charge3 did) and the new "find my phone" never works since the syncing is so random.
Hopefully they can fix all those issues quickly.
01-23-2024 16:35
01-23-2024 16:35
Best Answer01-23-2024 19:24
01-23-2024 19:24
Mine also isn't syncing. It won't restart the device on the menu. Pressing the button on the charger cable three times like YouTube videos show doesn't work. Looks like I just need the device to die battery wise. Gonna turn on GPS and hope the juice just dies and gives me relief from this buggy product.
I can't believe how bad the products have gotten over the years, everything I liked is basically gone. Wrote a Google Play review of 1 star I don't think the company replies to forum posts or play reviews. Crickets. Super disappointed.
Best Answer01-23-2024 19:26
01-23-2024 19:26
Also plugging onto charging cable doesn't bring up the charging screen. Never had a problem with charge 1 and 2. 3 was okay. But my 4 and 6 have the same bugging out unresponsive need the charging cable to reset. Now that doesn't even work. Wtf.
Best Answer01-24-2024 04:57
01-24-2024 04:57
Best Answer01-24-2024 06:18 - edited 01-24-2024 06:19
Had to take different steps to get the Charge 6 to sync. Sometimes quitting the Fitbit app and turning Bluetooth off and on on my phone gets it to sync. Other times, I close the app and restart my Fitbit and that gets it to sync.
Since it’s a known issue, I hope there’s an update to fix it.
01-24-2024 06:27
01-24-2024 06:27
I’d reach out for a replacement because it’s probably still under warranty; the syncing problem won’t be fixed but at least the Fitbit buttons and charging cable will restart it.
Best Answer01-24-2024 10:15
01-24-2024 10:15
Check out my post this morning, maybe related? Could you restart your device?
Best Answer01-24-2024 23:30
01-24-2024 23:30
Même problème avec Android ☹️
Best Answer01-25-2024 04:56
01-25-2024 04:56
Best Answer01-25-2024 06:19
01-25-2024 06:19
My sleep doesn’t always sync either. It’s a hit or miss. So frustrating. I don’t understand why. I wear my watch the same way every day/night but this morning no sleep information. 😣 😑
Best Answer01-25-2024 06:26
01-25-2024 06:26
Also restarted phone/watch nothing. So disappointing and disgusted
Best Answer01-25-2024 08:41
01-25-2024 08:41
Best Answer01-26-2024 06:59
01-26-2024 06:59
I'm sorry to hear you all still have issues. After all this time you should definitely contact Fitbit customer support. I now have a Charge 6 and when I had an earlier version (have had them all), I had some issues syncing. I contacted customer support and they did something on their end, not sure if it was a reboot of sorts or an upgrade. Anyway, it didn't help so they sent me a replacement. I found them extremely helpful. You can scroll down below to where it says "Company/contact us" or here's a link that will take you to the page with various ways to contact: https://myhelp.fitbit.com/s/support?language=en_US
I hope you get resolution soon.
