09-21-2024 19:01
09-21-2024 19:01
Today, Fitbit app calories burned tile no.loner is no longer agrees with the charge 6 on my wrist.
Best Answer09-22-2024 14:39
09-22-2024 14:39
Hello @Mite158
There's an issue on the Fitbit side that affects calorie tracking. Additionally, there have been issues on the Fitbit side that affects data syncing and data discrepancies between Fitbit devices and the Fitbit app. The team is aware of these issues and have been working on getting the problems fixed.
Hopefully, it won't take too much longer before the problems are fixed and you see your calories values match between your Fitbit and the app.
Best Answer05-12-2025 08:00
05-12-2025 08:00
I have a similar issue where the calories burned amount on my fitbit charge 6 matches the calories burned tile on the main page of the app, but when you go to the detailed page for calories burned it shows a much lower value.
