04-17-2025
07:39
13:56
LizzyFitbit
04-17-2025
07:39
13:56
LizzyFitbit
is there a way to choose the exercises you want in the exercise app? I don’t want to be scrolling all the way down every time I have to go swimming!
Moderator Edit: Clarified subject and formatting
04-19-2025 17:01
04-19-2025 17:01
Hi there, @bobdob. @June3205 Welcome to the community.
@June3205 Thanks for sharing your experience with your Charge 6. You may have noticed that all exercises have been added to your tracker. This was implemented to prevent the need for syncing each time exercise shortcuts were changed.
I understand your concern regarding this change and the best way to make your voice heard is to add your vote to the existing product feedback. This will allow our developers to track the demand of this request over time.
@bobdob Thanks for helping out our new friend. Regarding your inquiry, please note that your tracker will auto-detect your exercise based on how you move. Because of this, sometimes if your motion is quite similar to another type of exercise, it might pick the activity it thinks is the closest match to give you credit for your efforts. You can always turn off this function by following the steps described here.
04-17-2025 11:26 - edited 04-17-2025 11:26
It is supposed to learn your most frequently-used choices and put them at the top of the list (before the "more" button). Unfortunately for me it also adds ones that are incorrectly auto-detected, which is kind of funny.
04-19-2025 17:01
04-19-2025 17:01
