Can I enlarge my Charge 6 screen?
ANSWERED
Does anybody know how to enlarge the print on the screen this is the biggest reason I decided to try this out?
1 BEST ANSWER
Accepted Solutions
@TH1431 on the Charge 6, scroll to Settings, then tap that, scroll down to Magnify Settings. You can enable/disable here, and set the zoom to 2x or 3x. Once enabled, a triple-tap on the screen will enlarge (and you can drag around to see more), and triple-tapping again will return to normal.
3 REPLIES 3
Hi @TH1431 you can't change the size of the font on the screen or the app.
Stepping in the U.S.A. since September 2013. Android 14
Thank you for your help
