Can't have 2 Fitbit paired... ridiculous
ANSWERED
I remember when I had the Alta HR and went to the inspire 2. Was able to have them both paired. Now that I have the charge 6, I can't have 2 paired. I don't always want to wear the bulkier charge 6. I like to wear watches so when I do, I put the smaller Fitbit on my right wrist 🙂
Seems odd I can't have two devices paired to switch between them.
1 BEST ANSWER
Accepted Solutions
I think you could have the Alta HR paired with the Charge 6. It's that you could have the Alta HR paired because it is an older device.  It's just that you can't have 2 newer devices paired with each other.  They used to say it was because you couldn't have 2 devices that used the app store, whatever that meant.  Once the  Alta HR dies, then you will be out of luck, but until then, you can should still be able to use it with any newer device.  I know, still far from ideal, and has gotten many complaints over the years but haven't seen any move to change it.  Has been this way for several years.
2 REPLIES 2
Seems so odd. Wish they could fix this.
