06-24-2025
10:43
07:35
DavidFitbit
06-24-2025
10:43
07:35
DavidFitbit
So I bought my Charge 6 after my Charge 5 went dead, and I was wondering if the high AZM numbers were normal. I'll be sitting at work, and it'll give me >100 minutes where my charge 5 only gave me like 15 if I wasn't active through the day. I've seen similar posts, but I already checked the DoB after switching to Google, and it's correct. Any way I could fix it?
Moderator's action: Clarified subject
06-25-2025 15:20
06-25-2025 15:20
Hello @guwonssi
When you see the high AZM numbers, have you had a chance to look at your heart rate graph to see if it confirms that your HR was in the higher ranges?
I know that my heart rate will spike when I'm very excited or anxious and I'll see a higher AZM number, as a result.
06-28-2025 10:54
06-28-2025 10:54
Yeah..I think that was it cause there was spikes like you mentioned.
