11-26-2025
14:48
15:28
JuanFitbit
11-26-2025
14:48
15:28
JuanFitbit
Did you find any solution for this? I am having the same issue.
Best Answer11-26-2025 15:27
11-26-2025 15:27
@Kallol , A warm welcome to the Community! Thank you for your message.
I moved your post over here, as the thread where you posted is a year old.
Here you'll receive the up to date information.
As you read the previos thread, I asume that you already tried to restart the Charge 6, right?
Did you try to change the clock face? How do I change the clock face on my Fitbit device?
Best Answer11-26-2025 18:03
11-26-2025 18:03
Yes, I tried restarting the device but that did not help. I did try to change the the clock face to the default one called "First Lane". That did not show-up the red pixel. However, the heart pulse on the top and steps/charge info at the bottom of that default clock goes away.
Also, I understand and appreciate the suggestion to change the clock face. But I still fell that's not a sustainable solution.
Please let me know how to fic this issue permanently.
Regards,
Best Answer11-27-2025 08:21
11-27-2025 08:21
@Kallol Thank you for your reply and further info.
Sometimes changing the clock face helps permanently with display issues, as it allows some pixels to "restart"and get in sync again.
As this was not your case and the improvement was not as wished, the next steps should be to contact Support. They have more tools to investigate your case and provide you with further options.
Fill out the form. You'll see some recommended articles to read and then you'll see the options to get in touch with our team .
