08-08-2025 09:08 - edited 08-08-2025 09:38
Charge 6 | System 66.20001.214.24
Android phone | OS Version 14
Fitbit app | Version 4.48
Left and right swipes on my Charge 6 have stopped working as they should. On the clock/home screen, the L and R swipes still do something; the equivalent of tapping the bottom of the clock/home screen which cycles through the metrics at the bottom of the home screen ( Date > Steps > Calories > etc.).
Up and down swipes function as expected.
I am inclined to think this is a physical issue, as opposed to data, firmware or software issue, however I did try fully charging and my synchronized phone/Charge restarts to no improvement.
Any ideas of other things I can attempt, or am I reaching out to Support for Warranty Service?
Edit: for grammar
Best Answer08-08-2025 10:56
08-08-2025 10:56
Hello @pjpjr
It looks like you've done the troubleshooting that we normally recommend.
It may be better to work with Support (<-- click) on this issue. Complete the prompt in Step 1. Tap Continue for Step 2 (ignore Resources) to get to Step 3, for the Support contact options.
08-08-2025 10:56
08-08-2025 10:56
Hello @pjpjr
08-09-2025 04:36 - edited 08-11-2025 03:59
Final Update: When I reached my 3000 calories out goal yesterday, the screen had gone to dimly lit and the 3000 cal goal notification appeared as a thin line horizontally across the bottom of the screen.
@RiekoC was spot on as I reached out to Support and they asked me to try the one thing I usually forget - changing the Clock face after resetting my Charge; which unfortunately was not successful.
This issue has been diagnosed as Screen Failure and the Warranty process is already in-flight.
Edit: I will add that, with the exception of the inaccessible, dimly-lit screen and reduced time on a charge likely due to this defective screen, my Charge 6 continues to function normally with the Fitbit App. It also continues to autodetect exercises and appears to be correct on which of my exercises I am actually doing. This is not overly surprising as my prior Charge 4 similarly did this for ~16 months after it's screen was damaged ~4 years after purchase.
08-09-2025 10:20
08-09-2025 10:20
Hello @pjpjr
Thanks for letting us know that you contacted Support & they confirmed you have a defective device. Hope it won't take too long for your replacement to arrive.
