12-09-2025
13:10
14:42
MaCrisGBFitbit
12-09-2025
13:10
14:42
MaCrisGBFitbit
I can no longer manually lig steps - perhaps since most recent update. Plus sign only gives option to log sleep. Settings heading “manage data” only gives option to delete data.
Best Answer12-09-2025 14:48
12-09-2025 14:48
Hello @TWoodcock! Welcome to the Fitbit Community! It's great to have you here!
Thank you for letting us know that you are unable to log steps manually.
You can add an activity like walk for example and with the distance the steps will be logged, in the following article you will find more information about add or edit your activities: How to add, edit, or delete Fitbit data & activities
Best Answer12-09-2025 15:36
12-09-2025 15:36
Best Answer12-11-2025 15:26
12-11-2025 15:26
Hello @TWoodcock
When you tap the Exercise days tile and open the Exercise page, do you see the + Add exercise icon at the bottom of the page?
Best Answer12-13-2025 07:01
12-13-2025 07:01
Thank you - for whatever reason this glitch disappeared overnight and everything is working as it had before, so the problem is gone. Thank you for your input anyway!
12-16-2025 15:48
12-16-2025 15:48
Hello @TWoodcock
Thanks for letting us know that the problem went away. It sounds to me like the issue was fixed in the back end, which is good.
