03-25-2024
16:38
17:27
JuanFitbit
03-25-2024
16:38
17:27
JuanFitbit
The connection devise on my charge 4 broke so I 'upgraded' to a charge 6. Feels as though I downgraded - no altimeter - yet clearly shows an icon for steps - no weather. I wish I had stayed with a 4 .
03-25-2024 16:56
03-25-2024 16:56
Hi @TFEC Charge 5 and Charge 6 do not have the altimeter. Are you able to return the Charge 6? The Charge 4, if it's still working, can be used with an alternative band. A protective band cover for the Charge 4, at Amazon, will enclose the pebble portion and allow you to continue using it.
03-25-2024 16:56
03-25-2024 16:56
03-26-2024 08:02
03-26-2024 08:02
I feel the same way Odyssey 13😕
I moved from the sense 2
And I do not like this downgrade
Best Answer03-26-2024 12:13
03-26-2024 12:13
Best Answer03-26-2024 12:18
03-26-2024 12:18
@TFECyou can always get with support.
here are the support contacts I've gleaned over the years on the forums.
when there is someone available, chat is an option. Phone or X/Twitter works well, too.
https://myhelp.fitbit.com/s/support?language=en_US
Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
Best Answer03-26-2024 12:20
03-26-2024 12:20
12:54
12:35
AndreaFitbit
03-26-2024
12:54
12:35
AndreaFitbit
Thank you. I am going to try the band idea you suggested. I think the older
4 will hold a charge.
Thanks again
I purchased the band you suggested and was able to charge the older 4. Put the 6 into its box. Happy now - can see the weather and the stairs! Thank you so very much for your suggestion
03-30-2024 16:31
03-30-2024 16:31
Wonderful news, @TFEC Now you can get back to your journey!
Best Answer05-16-2024 09:39
05-16-2024 09:39
Hi Odyssey13,
Can I have a link for this protective band cover for Charge 4?
The connection device has broken on my Charge 4 and the spring is gone.
Thank you.
Best Answer05-16-2024 12:45
05-16-2024 12:45
Hi @bry1216 there are a few, but here is one from Amazon (click to view) and the images show you how it works
05-18-2024 09:03
05-18-2024 09:03
Thank you Odyssey13!
I have requested a return of Charge 6. Won't be buying a new Charge until they put the altimeter/floors back in.
