01-01-2025
23:34
12:06
MarioSFitbit
01-01-2025
23:34
12:06
MarioSFitbit
Hi! I have been using a Charge 6 for the last week and it worked perfectly fine until 2 days ago, but for the last 2 nights it has not recorded sleep phases or shown a sleep score. I know this happened to many but did not really find a solution. I tried reset and app update.
Has everyone actually solved this problem? My way of wearing it is always the same and it worked for the first few nights.
Any ideas?
Thanks a lot!
09-23-2025 00:11
09-23-2025 00:11
I had the same issue with my Charge 6 not showing sleep score or phases. What worked for me was:
Wearing it slightly higher on the wrist (not too close to the hand).
Doing a quick sync in the Fitbit app right before going to bed. Since trying this, the sleep score has been logging fine again. If you want to read more tips, I found this resource helpful click here . Hope it helps someone else too!e power of collaboration! Hope it helps someone else too!
09-23-2025 00:28
09-23-2025 00:28
09-25-2025 15:12
09-25-2025 15:12
I have the same problem. Everything heart rate related is not recorded anymore. I tried all resets and updates and reboot and cache deletion. The charge 6 obviously tracks my heart rate but won't send that info to the Fitbit app. No solution online has worked.
Best Answer09-26-2025 12:30
09-26-2025 12:30
Hello @InaMarieD
Are you seeing your heart rate tracking on your Charge 6, but nothing when you sync to the Fitbit app?
Do you see a green light on the back of your Charge 6? That's the optical heart rate sensor.
If you don't see the green light, have you confirmed that Heart rate is turned on in the Settings tile on your Charge 6?
