11-26-2025
12:44
04:23
HorareyFitbit
11-26-2025
12:44
04:23
HorareyFitbit
Just fed up, spoke to someone on Fitbit again said to do update which I have made no difference, two days ago battery 87per cent now 47per cent, sleep score not working either I turned it from sensitive to normal And normal to sensitive nothing is working since end of August.have re set I just give up.
Best Answer11-27-2025 04:51
11-27-2025 04:51
Hi @Jan871, it's great to see that you've visited the Fitbit Community!
I appreciate you telling me about your situation regarding your sleep score.
Because you already started the process with our support team, I recommend for your case to keep the interaction with them since they have more tools that might be helpful for your situation.
