08-10-2024 15:04
08-10-2024 15:04
Charge 6 active zone minutes not accurate. 165 zone minuteswhich I have never had this many on any Charge I had. I am 70 years old and I exercise daily but these zone minutes are way off. I was at 34 zone minutes before I got out of bed.
Best Answer08-11-2024 03:23
08-11-2024 03:23
Hi, @D8 , your Active Zone Minutes are based on your detected heart rate. Have you checked what the Fitbit recorded as your heart rate during this time? Your heart rate zones will be based on 220 minus your age, so at age 70 your theoretical maximum heart rate will be 150. Fitbit personalises your heart rate zones using your “heart rate reserve” which is your maximum heart rate minus your resting heart rate, and divides it into Light, Moderate, Vigorous and Peak (depending on the per cent of your reserve you are using).
You can check what Fitbit calculates as your zones in the app. From the opening, Today, screen of the app click on Active Zone Minutes and scroll down to see your personalised zones.
If your heart rate is showing as in the Moderate Zone you will earn one AZM for each minute. However, at Vigorous or Peak you will earn 2 AZMs for every minute. If you are earning an unusually high number of AZM minutes when you have not been exercising, then either your heart rate is unusually high (perhaps due to stress or illness) or your Fitbit is not correctly detecting your heart rate during that time (possibly due to wearing your Fitbit too loosely or too tight or because of excess sweat, etc, interfering with signal)
If these calculations seem wrong to you, then you can create your own custom zones.
For full information on Active Zone Minutes, including how to set your own custom zones, please see this help article .
I hope this helps. Welcome to the Community Forums!
12-16-2024 10:23
12-16-2024 10:23
There is definitely a big problem with zone mins. I have a charge 6 and at eight o'clock every morning my App records that I've got 150 Zone mins and burnt loads of calories when I've been sat on a bus ? My workouts always record the correct Zone minutes. Not sure what's going on
Best Answer12-16-2024 10:25
12-16-2024 10:25
I've got exactly the same issue, the Zone minutes appear the same time each morning when I'm either in bed or on a bus. Definitely something wrong.
Best Answer12-16-2024 11:14
12-16-2024 11:14
Hi, @Bendymavis , I have sometimes found that Fitbit accidentally records a bus journey as an exercise activity - this particularly happens to me on local buses which are not smooth - similar to steps sometimes being recorded when driving on bumpy roads or in cars with dodgy transmission. Could this be what is happening in your case?
12-16-2024 11:25
12-16-2024 11:25
