03-12-2024
19:33
10:19
LizzyFitbit
03-12-2024
19:33
10:19
LizzyFitbit
sent one charge 6 back due to
Loose band connector and the replacement is worse with two bad connectors. I know google has sabotaged Fitbit to push pixel. I think it’s criminal!
Moderator Edit: Clarified subject and word choice
03-13-2024 06:35
03-13-2024 06:35
@Utopianmovement Good day to you. Thanks for your post about the Fitbit Charge 6 band connectors and your feedback.
Please note that production lots are not perfect. That is the reason there is a warranty on the products. I am sorry this has happened to you twice in a row. However, your device has warranty. Did you contact Fitbit support to claim the change? If so, please keep in touch with support. They will provide you with a suitable resolution.
If you still have not contacted regarding your replacement, I advise you to contact customer support. Click here, then click on "Broken Armband." There you can report your inquiry. Thanks in advance!
