06-13-2025
22:19
09:41
LizzyFitbit
06-13-2025
22:19
09:41
LizzyFitbit
The battery of my charge 6 (less than 1 year old) started draining really quickly, within 4-5 hours of fully recharging, about 3 days ago. What can I do?
06-14-2025 09:51
06-14-2025 09:51
Welcome to the community forums, @cheebai73.
Thanks for letting me know about your Charge 6. As with any other electronic device, the battery will depend on how often certain features are used. If you use built-in GPS continuously, your Charge 6 battery life will be up to 5 hours. The battery will also be impacted if you turn Always-On display or when tracking SpO2 data.
With this in mind, I'd recommend following the tips to maximize the battery life described in this help article and monitor your tracker's behavior in the next few days.
06-16-2025 08:27 - edited 06-16-2025 18:12
Thanks.
Internal GPS and SpO2 monitoring have been off several days and I have never used always-on. However the problem still persists. It was all good
until about a week ago when it started to drain really fast. (Before the battery problems started, I used dynamic GPS and monitored SpO2 and it lasted several days). I've tried restarting and did a factory reset several days ago.
06-17-2025 10:48 - edited 06-17-2025 10:48
Hi there, @cheebai73.
Thanks for sharing additional details, and taking the time to troubleshoot your Charge 6. Because the battery is still not lasting after exhausting our tips, I'd like to get you connected with our Support team. I’m sharing a link to a form for you to fill out with so we can look into this further. I’ll keep an eye out for your response specifically, so please let me know once you’ve filled it out.
06-17-2025 23:43
06-17-2025 23:43
Thanks! I've submitted the request using the link provided. Thanks for your help.
07-16-2025 04:11 - edited 07-16-2025 04:23
I’m having the same issue with my charge 6. The battery first started draining because Google Wallet kept disconnecting from the phone. Now the battery just depletes. It doesn’t last more than a few hours. I have left the app open, uninstalled and reinstalled the app, turned Bluetooth off and on, turned the device off and on using both the option on the Fitbit and restarting by using the charger. As a last resort, I factory reset the device. Restarting the device causes the battery to sharply drain i. e., going from 50% to 4%. GPS is phone only. Screen wake is set to manual. None of the steps to “fix” this work.
