05-01-2025 00:53
05-01-2025 00:53
My charge 6 screen has gone blank after setting it for a swim activity. I have repeatedly tried double tapping, pressing and holding the button on the side of the device for 10 seconds, resetting by pressing the button on the charger 3 times within 8 seconds and uninstalling and reinstalling the app. On several occasions the device has vibrated once but nothing has shown up on the screen. If I put the device on my wrist and remove it I see a green flashing light on the back of the device. Any suggestions other than get it replaced?
Best Answer05-02-2025 12:16
05-02-2025 12:16
You might still have the Water Lock feature still turned on.
I found that I had to tap very firmly on the display with some force to turn off the Water Lock feature. Please give this a try and let us know if you were able to restore your display.
05-02-2025 12:37
05-02-2025 12:37
Best Answer05-03-2025 09:38 - edited 05-03-2025 09:40
Welcome to the Fitbit Community, @Penflo55. I'm sorry to hear that your Charge 6 display got blank after a swim. I'll be happy to assist.
Could you please try the steps of help article: Why isn't my Fitbit device's battery charging? in order to see if your tracker charges.
Thank you for your advise and assistance @RiekoC.
05-05-2025 02:27
05-05-2025 02:27
Best Answer05-06-2025 09:20
05-06-2025 09:20
Hi @Penflo55. Thank you for your messages and efforts. Our Team will be more than happy to have a closer look at this.
Please fill up this form with all the needed information. Our Team will reach back to you afterwards.
Please keep in mind, that this form is for you alone. If other users try to fill it up, they might not get an answer from Support.
05-08-2025 04:23
05-08-2025 04:23
05-08-2025 11:14
05-08-2025 11:14
Thanks for getting back to us and for letting us know that you already have your replacement @Penflo55.
If you have time, check out our Health & Wellness board where you can make new friends, create your own topics and find tips, as well as encouragement from other members.
Best wishes for an active day!
05-27-2025 01:48
05-27-2025 01:48
Mine has done the same, annoying as I've only had it 4 days, what shall I do?
Best Answer05-27-2025 10:09
05-27-2025 10:09
Welcome to the Fitbit Community, @YourCrackers. I'm sorry to hear that your Charge 6 also shows a black screen after swimming with it. I'll be happy to assist.
Best Answer05-30-2025 14:01
05-30-2025 14:01
Hello @YourCrackers
If the water lock feature was turned on when you went swimming, it might still be on. I found that it took very firm tapping on the display in order to turn off the water lock feature. Please try tapping very firmly on your Charge 6 display to see if that will restore the clock face.
