Charge 6 blank screen and will not reset
Hi,
I have had the Fitbit charge 6 for nearly 2 weeks and yesterday the screen went blank and had at least 20% battery still. I tried to charge it but nothing is coming up on the screen. when I plug the charger into the Fitbit it vibrates, also if i push the button on the side of the watch it vibrates.
I have followed the steps by switching to different plug and still no luck and I have tried multiple times to reset the device via the charger button (pushing 3 times in 8 seconds) As well as pulling the cable in and out of the plug to hard reset it but still no luck.
Is there a way to do a hard reset of the device via the button? Phone will not find or sync to the device either as it says the battery is low.
Also to add i have tried cleaning the back of the watch charging inlet as well as the charger itself.
116 REPLIES 116
Having the same issue. It will not display on the face. I see a light at the back, it’s been on charge with a New Fitbit. Able (brought from Fitbit) I brought it in February. I’ve tried all the 3x in 8 seconds. It will not display the code to pair up again.
It's broken.  Contact Fitbit directly to replace. When they ask you to return,  ONLY return the watch,  not the charger of band. Because they only return to you the watch base.....Hope this helps..Sent from my Galaxy
Thanks for your reply. The last person I spoke to wanted me to plug it in to the charger while he was on the phone to me but I didn't have the charger with me so I have to call them back, that was several days ago. It's so time-consuming. He seemed to act as though it was fixable, insisting that if I go through these steps with him it'll be fine. What makes you think it's broken, has it happened to you? I've lost all faith in Fitbit, this is the second one that broke. Is it a problem with the charge 5's and 6's do you think?
Not sure if it's the model or not, because I had the same issue with the Luxe. I know it's annoying but they are told to walk thru all the suggested remedies before they'll replace.  My issue with the whole discussion was he was calling from India, I think,  I couldn't understand him, so I had to ask him to repeat & repeat & repeat. SO annoying....a very long phone call,  so be very patient...:)Sent from my Galaxy
Thanks again. So they sent you a new luxe? Have you had no problems with it? Yeah, I opted for the online chat the second time, even more time consuming but better than a phone call.
I had a Luxe before the Charge 6.  Both were replaced. The luxe worked for years after it was replaced.  I changed watches to the Charge 6 & recently had to replace it.Sent from my Galaxy
Oh gotcha, thanks. Knowing my luck, by the time this is resolved they'll say I'm out of warranty...😩
Well, after a good run of almost 8 months, which by comparison to my experience with the charge 5, is truly impressive, my charge 6 has packed up. It had been completely rock solid until last week, not a single glitch, the battery would last at least 8 days, and never once needed a reset. So a few days ago I noticed it was unresponsive but thought, maybe I forgot to charge it, so I plugged it in and it woke but rebooted a few times which was also odd. I left it to get a full charge then it seemed fine again but 2 days later it was unresponsive again. This time when I knew something was wrong because I had just fully charged it and when I plugged it in, it would not turn on, instead, it was just vibrating every few seconds. Tried to reset but no luck, still the same vibration every few seconds as if it was trying to start but couldn't. Contacted support, the troubleshooting was a bit odd as even after explaining everything I was still asked to plug it in and try resetting, then asked to change the clock face which of course was not possible because the device could not be connected to. I have been offered a replacement or refund, both require me to send the faulty unit back.
I'm a bit disillusioned with Fitbit, from all the products I've owned over the past 10 years (for context, I had 5 charge 5 units, 1 was purchased and 4 replacements because they kept failing), none have lasted more than 8 months (apart from a charge 2 which is still working, that was the 3rd replacement device). What is going on? Is it me? Am I wearing it wrong? I can't put it down to bad luck, I don't have such problems like this with any other product I own. Why is the reliability of the charge line of products so bad?
I will probably take the replacement because I don't know of any other product that suits my needs as well but at this point, I consider every purchase from Fitbit a device subscription because I will need to buy a new one once the warranty if over.
Yes they sent me a second one but after about 1 month it also went blank. So I did the online chat as well as emails and they in the end refunded me after I returned it.
Fitbit treated me very well. I am just sorry the Charge 6 didn’t work out as I really liked it. I am currently wearing my charge 4 and it had been very faithful.
When their new Charge comes out I’ll get it for sure.
Sent from Yahoo Mail for iPhone
Yeah, I can't complain about being offered a replacement or a full refund, despite it being a real pain for me (because I'm travelling, so I do not have a fixed address at the moment to arrange the return shipping label), the bigger issue is just how poor the reliability is.
Even if the entire replacement process was completely hassle-free, I'm far more concerned about the number of failed devices and why this is happening so often. From having 10 different charge units (various models over a number of years), only one has ever lasted more than 8 months ...... is that normal?
What do you mean you consider it a "device subscription". Any idea how long the warranty is for?
I bet it was a charge 4?
This is my own experience, maybe others have never had a device fail, but for me, I have to purchase a new device every year (once it's out of warranty). So what's the point in owning the device? It might as well be a subscription model (I think that's what whoop are doing) where you don't own the hardware (which is fine by me because it's not worth owning), and at least you know upfront that you need to shell out every year for continuing to use the service. This would also remove the feeling of being ripped off or scammed by paying for something that keeps breaking. I'm not saying that I want that, but based on how often I need to buy a new device, it might as well be.
Charge 2 , I had 2 replacements, the 2nd one is amazingly still the only device to last more than 8 months
Charge 5, had 5 replacements, and all failed. Purchased a new one, it failed after 3 months, I returned it and purchased the Charge 6 (was hoping they ironed out all the issues with the 5), which has now failed after 8 months
Not had the charge 4, I heard it was reliable, is that your experience?
Contact customer support. It’s a lengthy process going through all their processs but it’s worked for me getting replacement as well as a final refund
Other than my disappointing Charge 6 experiences my charge 4 has operated as expected since Christmas 2020.
Good to know, it might be a better idea for me to find a second-hand Charge 4 instead of buying a new Charge 6 😛
Yes until they fine out with a new one
Best case is refund and give their next new one a try.
Used my charge 4 since Christmas 2020 except for the short period that I had 2 charge 6 that both quit. Refund and using charge 4 until they give us another model to try!
Well, if nothing else, it is good to know it's not just me having 'bad luck' with this product, thanks for confirming what I already suspected. I was really hoping the Charge 6 would not suffer from the same reliability issue as the 5, but it looks like it's another dud and probably a safer option to get a refund and wait for the 7 now.
Agree. I like Fitbit when they work and as I’ve said my
Charge 4 is still going. I’ll buy a new model when they come out.
