02-05-2025 07:51
02-05-2025 07:51
When I use the Charge 6 for my treadmill walk,it always shows less distance walked. How to fix it ? Or calibrate it ?
Best Answer02-13-2025 17:09
Silver Fitbit Product Experts share support knowledge on the forums and advocate for the betterment of Fitbit products and services. Learn more
02-13-2025 17:09
@K_ajith Less distance compared to the counter on the treadmill monitor? It's possible how you swing your arms or if you are stepping lightly. That's my experience. For example, when I walk the same lap around the park vs jog the same lap, my walks end up with less steps/miles vs when I jog.
02-14-2025 08:07 - edited 02-14-2025 08:07
Hi @K_ajith and @KatherineNY Thanks for stopping by, I hope you're doing well.
Let me help you with the distance accuracy of your Charge 6.
In addition to what @KatherineNY says, your Charge 6 uses the formula below to calculate distance. Your stride length is determined by your height and sex.
Steps x Stride Length = Distance Traveled
You can update your stride length if you need to. For more information, see our help article How does my Fitbit device calculate my daily activity? below the section "Can I change my stride length in my Fitbit account?"
