07-19-2024 02:36
07-19-2024 02:36
I seem to have gotten lint or some other gunk on the gap between the screen and the body of the charge 6.
It's such I small gap I can't get anything in to scrape it, it's smaller than a sewing needle!
Any suggestions?
Best Answer07-20-2024 13:19
07-20-2024 13:19
Hello @kamado69
I've used an extra soft toothbrush for cleaning. I wonder if this might work for you.
Best Answer09-08-2025 15:49
09-08-2025 15:49
I have the same issue. Did you figure something out? I was thinking a compressed air duster.
Best Answer09-09-2025 10:07
09-09-2025 10:07
Welcome @kamado69 & @VinnySwish to the Fitbit Community! It's great to have you here!
Let me help you with the small gap you see between the screen and the body of your Charge 6.
Thank you @RiekoC for your contribution.
While this may look like something that has a minimun impact, i want to make sure the screen is properlu placed. The gap you see in one side, is present in the other side?
If it not the case, i would recommend that you contact our technical support so they can investigate in depth.
