05-01-2024
15:13
06:53
LizzyFitbit
05-01-2024
15:13
06:53
LizzyFitbit
The most recent update changed the sleep data display. More changes today--no more REM, Light, and Deep sleep data--only number of minutes spent Awake, Restless, or Asleep. This is very disappointing. Why is Google taking away valuable information from this tracker?
05-02-2024 11:25
05-02-2024 11:25
Hello @Nanchanah
Sorry to see that you didn't get your sleep stage information for last night. Google hasn't removed sleep stages from the Fitbit app.
Did you get any data for your Health Metrics for the same period?
Since you only got Awake, Restless, or Asleep data, that indicates to me that your heart rate sensor was off. The heart rate sensor is needed for tracking sleep stages. Have you had a chance to see if your heart sensor is on? You can check by putting your finger across the back of your Charge 6, then lifting your finger. You should see a green light on the back of the device when you lift your finger.
If you don't see the green light, you should double check that the sensor didn't accidentally get turned off:
Let us know if you were able to get your heart rate sensor turned back on.
05-02-2024 12:26
05-02-2024 12:26
05-02-2024 17:25
05-02-2024 17:25
My charge 6 has so many glitches, I will probably cancel my premium subscription. I have had every Fitbit since the Fitbug and have never had so many issues. I have followed every recommendation that has been thrown my way on the Charge 6. I haven’t had a sleep score in forever. The latest note says, “you don’t have 14 nights of sleep data in April. However, the app shows sleep data for every day in April. Secondly, breathing rate hasn’t worked in a month. Thirdly, the heart rate data is way off. Does anyone else see all these issues about the time Google took over?
05-23-2024 10:27
05-23-2024 10:27
I’ve had the same problem. For a couple of days all is well, then just minimal sleep data, then all the data comes back. The band is appropriately tight. Heart monitor is on.
06-09-2024 10:39
06-09-2024 10:39
I’m glad to hear this! It happened to me this morning and I was super disappointed to think the info had been removed. I hope mine goes back as well. (My heart monitor is on and working).
06-09-2024 11:09
06-09-2024 11:09
06-19-2024 00:44
06-19-2024 00:44
I have the same problem for the last three days. Heart sensor is on. I will be stopping using it.
06-19-2024 05:03
06-19-2024 05:03
06-19-2024 11:37
06-19-2024 11:37
@Moondoggiefarm @CynK_111 Welcome to the forums. @Hayfords Nice to see you active in the forums again. Thanks for your posts about sleep stages.
I recommend you take a look at the following article: Why don't I see sleep stages today?. Several factors ceom into play. Here you find some tips.
@Moondoggiefarm I am glad you mention it. Manually tracking sleep will prevent sleep stages from being recorded. It is best to let it log your sleep automatically. I am glad it is working now.
06-19-2024 13:43
06-19-2024 13:43
06-19-2024 13:47 - edited 06-19-2024 14:15
No you should get awake REM LIGHT and DEEP. If you dont sleep very long or you dont have the sensitivity turned up you may not get REM LIGHT and DEEP but if all set up and you sleep over 3 hours I think you should get those
Best Answer06-19-2024 14:11
06-19-2024 14:11
Best Answer07-22-2024 09:39
07-22-2024 09:39
Doesn't work for me. I've also restarted devices, force stop and cleared cache. New Fitbit no sleep stages
08-06-2024 13:00
08-06-2024 13:00
I've had the same problem with my new Fitbit Charge 6
08-29-2024 23:16
08-29-2024 23:16
i have encountered same problem here. Used to have sleep report with score and rem deep sleep info. i did change any setting of my fitbit 6, just all a sudden, no more sleep score this morning.
What could i do? sleep tracking is the most valuable info to me.
08-30-2024 05:05
08-30-2024 05:05
Its frustrating. Since I received by Fitbit Charge 6 I have gotten sleep stages and score twice.
Best Answer08-30-2024 09:43
08-30-2024 09:43
09-18-2024 14:47
09-18-2024 14:47
I have had my Charge 6 for 2 months and I have gotten sleep stages 3 times. I had the same problem with Charge 5. I have tried everything recommended in these posts. I guess I give up and look for better options
Best Answer09-19-2024 02:26
09-19-2024 02:26
