10-15-2023 12:40
10-15-2023 12:40
My Charge 6 wakes up if I press the button or if I tap, but not if I turn my wrist. The Wake setting appears greyed out on the device. Does Wake-on-wrist-turn no longer work?
Thanks,
David
12-05-2023 19:05
12-05-2023 19:05
@SiliconValley47 -- In addition to checking sleep mode, check that DND is not turned on. You cannot change the wake setting if either DND or Sleep is active.
Scott | Baltimore MD
12-04-2023 23:55
12-04-2023 23:55
Mine used to wake up but now stopped and I cannot change the setting from manual. I change it to auto and then it goes back to manual.
Best Answer12-05-2023 17:37
12-05-2023 17:37
Check to be sure you are not in sleep mode, it will not light unless you push the side button in sleep mode.
12-05-2023 19:05
12-05-2023 19:05
12-06-2023 00:19
12-06-2023 00:19
It was sleep mode, thanks!
