04-16-2026
13:29
16:09
MariLuFitbit
04-16-2026
13:29
16:09
MariLuFitbit
I just started using my new charge 6 for bike rides and noticed the elevation info is missing. My other watch is the Versa which had this info. I've researched and found out it doesn't have that capability which kinda blows. Can I add the Versa onto the Fitbit app so I can wear that when riding?
04-16-2026 16:46
04-16-2026 16:46
@pizzakid13, Welcome on board to our community forums!
I totally understand your feeling, I miss that option on my Charge 6 too.
According to this help article, only one device that uses the App Gallery (for changing clock faces) can connect to an account at a time. However, you can switch between them: connect your Versa to track your riding and then disconnect it to switch back to the Charge 6 to track the rest of your day. Just keep in mind you will need to synchronize before disconnecting any of them to avoid losing information.
04-16-2026 17:29
04-16-2026 17:29
So you're saying that both watches are kept in the account but only one can be used at a time or do I have to delete and add a device every single time? Thanks.
Best Answer04-17-2026 06:36 - edited 04-17-2026 06:36
@pizzakid13 Sorry, but you need to delete one then add the other as a new device every time to switch.
Laurie | Maryland
Best Answer04-17-2026 07:43
04-17-2026 07:43
Ok, that sucks. I'll just use a different app.
