Charge 6 goes dead even though there is still battery
Charge 6 just goes black and unresponsive have to restart on charger and it shows plenty of battery. Keep having to reboot
2 REPLIES 2
Hi there @Pepsicat_0!
We love to see you here!
Thank you for reporting this situation and for all your efforts.
Does your Charge 6 go black randomly or does it happen for example when you start an exercise?
I suggest you try to change the clock face.
There are a couple of different ways to restart the Charge 6 too, you can give it a try:
  1. Connect your device to the charging cable.
  2. Press the button located on the flat end of the charger 3 times with one-second pause between each press. Then wait 10 seconds or until the Fitbit logo appears.
  3. Another way to restart your device is to unplug it, wait a second, and plug it back in. Repeat this process 3 times in an 8 seconds interval and then wait 10 seconds until the device restarts.
It goes black without any activity usually in the night. I have rebooted it
by pressing the button and unplugging. Battery is only lasting two days.
