01-15-2024 22:33
01-15-2024 22:33
After charging today, the charge6 has developed a HORIZONTAL line at the bottom of the screen that does not go away after a restart. It's super distracting as it is at full brightness, much brighter than the rest of the screen.
I'm assuming it is a hardware issue. Where do I go to ask for a warranty repair ?
Best Answer01-15-2024 23:47
01-15-2024 23:47
Hi @plotprx.
Have you first tried restarting the watch? Also if it's only on the watch face, I'd suggest changing watch faces to see if that makes any difference.
If it's a hardware issue you can contact customer support (here). Depending on the time in your country, different contact options might be available/unavailable.
01-15-2024 23:47
01-15-2024 23:47
Hi @plotprx.
01-16-2024 06:53
01-16-2024 06:53
Another person has reported a similar issue.
Best Answer06-03-2024 19:14
06-03-2024 19:14
I'm having the same issue. Randomly I have a super bright horizontal line at the bottom of the display no matter where I scroll. Were you able to fix yours?
Best Answer06-03-2024 20:58
06-03-2024 20:58
