01-30-2024
13:42
14:28
JuanFitbit
01-30-2024
13:42
14:28
JuanFitbit
The heartbeat is not detected. Did I do something wrong in the set up? This is the 2nd device I've gotten that did this so I'm thinking it could be user error. I can't figure it out! Help!!
Best Answer01-31-2024 05:05
01-31-2024 05:05
Hello, @K.OD, welcome to the community.
Thanks for letting me know about your situation with the Charge 6 that is not tracking heart rate.
I was able to confirm you contacted support and they were able to provide you with a solution, if you have any other questions or concerns, my best recommendation would be to contact them once again.
Best Answer01-31-2024 12:03
01-31-2024 12:03
This device is thrash 2 hours of cardio heart rate won’t go above 94 on my charge 5 was mor accurate Beyond frustrated
Best Answer02-01-2024 04:43
02-01-2024 04:43
Welcome to the community, @Thémself1977.
Thanks for sharing your situation with the heart rate tracking in your Charge 6.
I recommend you to restart the Charge 6 and make you sure to double check how to correctly wear it, please.
Once you've done this, let me know how the situation goes.
Best Answer08-12-2024 03:16
08-12-2024 03:16
I’ve bought my second charge 6 and it’s the same issue I’ve never seen a tracker that works better when you take it off
