12-17-2025
16:37
10:37
ManuFitbit
12-17-2025
16:37
10:37
ManuFitbit
Sometimes when I take my Charge 6 off the charger and put it on I get a fairly high heart rate reading when it starts recording. It drops fairly quickly but was just curious if anyone else has experienced this.
Moderator edit: clarified subject.
Best Answer12-18-2025 13:33
12-18-2025 13:33
Hello @CookiebakerT
Have you tried restarting your Charge 6 recently? That's the first troubleshooting step that I would try.
12-20-2025 08:31
12-20-2025 08:31
Hi @CookiebakerT and @RiekoC, welcome to the Fitbit Community! It's great to have you here!
Let me give you some details about how your Charge 6 tracks your heart rate. Thanks @RiekoC for your help.
PuerPulse technology uses rapidly flashing green LEDs to detect blood volume changes in wrist capillaries. For this reason, it's a expected behavior that some readings fluctuate right after you put your device on your wrist. However, the reading should normalize after a few seconds.
In addition, you can improve the accuracy of your heart rate data by following the tips listed in our help article How do I track heart rate with my Fitbit device > How to improve the accuracy of a heart rate readin...
12:49
13:39
ManuFitbit
12-20-2025
12:49
13:39
ManuFitbit
Thanks! Yes, it’s been restarted. I’m thinking maybe it’s an electrical thing. It seems if I unplug the charger from the wall with the Fitbit attached it does it. Last night I took the Fitbit off of the charger and then unplugged the charger from the wall and it didn’t have a crazy high spike. I’ll continue to try disconnecting it both ways and see what happens.
Not sure because this is sometimes a crazy high spike after unplugging the charger from the wall. It’s the only time that my HR gets that high.
On another note, my Fitbit sometimes buzzes my arm like 4 buzzes in a row. Why would it do that? My screen has not worked in many, many months (it just lights up white when it comes on) so I have no idea if it’s giving me a notification on the screen.
12-21-2025 16:40
12-21-2025 16:40
How do I delete this post? I no longer want it online?
