Charge 6 iOS not logging all sleep
For several weeks now, my Charge 6 isn’t logging my full night’s sleep. It’s only capturing a couple hours. Sensitivity is set to “normal” & I’ve tried restarting the Charge 6.
11 REPLIES 11
Hi @K-Roll,  Thanks for stopping by, I hope you're doing well.
Let me help you with your sleep tracking.
App updates are usually meant to improve the data tracking. Did you get an app update recently?
Another reason your sleep is not being detected lately, it may be because your sleep is not optimal (I speak by my own experience).
When you make significant movements like rolling over, your device records time spent awake. Normal mode is appropriate for most users.
Did you get at least a sleep log including your sleep pattern ? If you did, see our help article What should I know about Fitbit sleep stages? below "Why aren’t my sleep stages showing up today?"
In addition you cant take a look at this same help article but below the section "What are some tips for getting a good night's sleep?"
Hello @K-Roll
Have you had a chance to edit your sleep log in the Fitbit app? If so, what do you see after you correct your sleep & wake times?
Thank you for your response. I cannot edit the sleep start time (this is
what was incorrect) as the app says a log already exists for that time
period.
Hello @K-Roll
I've had that before.
Go to the previous day. The first part of your sleep is likely there as additional sleep. When you delete that log, you should be able to edit the other sleep log with the correct time for your sleep.
Ugh. Yesterday does include that increment of sleep. But it wasn’t in other
sleep- it was the log for the day. What’s the point of tracking if you have
to edit it all of the time? Still need to get to the root of the problem.
Hello @K-Roll
Just to confirm, you don't have any tattoos or scars on your wrist where you wear your Charge 6, right?
Are you also having issues with heart rate tracking? No problems with the green light on the back of the Charge 6?
One option that you could try is wearing your Charge 6 on the inside of your wrist. Some users have found that wearing the device on the inside of their wrist gave them more consistent sleep tracking.
No scars or tattoos & no issues with heart rate tracking. Green light
appears to be functioning correctly. I’ll try wearing it on the inside of
my wrist- thanks for the idea!
Thanks for confirming, @K-Roll .
I hope wearing the Fitbit on the inside of your wrist will work. If not, there's something not right with your device.
I have been having the same issue for the past month and have tried everything I can discover on help sites with no resolution.
It isn’t sharp movements and interruptions. The Fitbit seems to arbitrarily record only half the hours either on the front or back end of a night’s sleep.
Another user suggested I try wearing the device on the inside of my wrist.
I’m going to try it, but it doesn’t explain why all of a sudden my device
quit working correctly.
