03-16-2024 13:05
03-16-2024 13:05
My charge 6 is way underestimating mileage. Units are set to feet/miles. I walk a couple miles a day and the most it shows in maybe 0.25 mi. Today we walked 1.9 miles per the MyFitnessPal tracker and my wife’s Charge 6 showed 1.5 miles. My charge 6 re order 0.53 miles. Have never found anything on a Fitbit that works as intended.
03-16-2024 14:03
03-16-2024 14:03
Hi, @Fschw! How many steps are you showing for this distance? If it's low, like 1000, I would suggest getting in touch with Fitbit Support, your device is not registering steps. If it's higher, like closer to 4000 steps, I would take a look at your metrics, like height and stride length and make sure they're correct.
MakMak | Community Council
03-16-2024 14:36
03-16-2024 14:36
Best Answer03-17-2024 13:13
03-17-2024 13:13
Hello @Fschw
You can set/confirm your height by:
To set your stride, click on this link and scroll to the bottom where it has the directions on how to set your stride: How does my Fitbit calculate my daily activity? (<-- click link)
Best Answer03-18-2024 10:06
03-18-2024 10:06
03-18-2024 11:12 - edited 03-18-2024 11:14
Hello @Fschw
The other way that I know of to update your personal info is via your profile on the fitbit.com website:
Best Answer03-18-2024 13:36
03-18-2024 13:36
Best Answer03-18-2024 14:29
03-18-2024 14:29
Best Answer03-19-2024 02:24
03-19-2024 02:24
Best Answer03-19-2024 02:42
03-19-2024 02:42
@Fschw This kind of distance inaccuracy reminds me of one use case when a user was tracking walks as an Outdoor Workout. By any chance, any of your steps are acquired during tracking the activity that may not be added to your daily distance (examples: Outdoor Workout, Bike - you'll get steps, you won't get distance)?
Best Answer03-19-2024 03:42
03-19-2024 03:42
Best Answer06-26-2024 05:15
06-26-2024 05:15
Just got my charge 6 two days ago and am already concerned with its accuracy. Different reading between the pedometer on the phone and the one on Fitbit. Woke up this morning with a distance showing already.
06-27-2024 13:16
06-27-2024 13:16
Hello @SunsetRunner
I suspect that the pedometer on your phone has a different way of tracking your steps compare to your Charge 6.
Your Charge 6 is a wrist worn tracker with a 3-axis accelerometer and uses arm movement to track steps. This is why users who push strollers & carts will often see fewer steps due to less arm movement.
You might be interested in this help article to better understand How does Fitbit calculate daily activity (<-- click link)
06-27-2024 13:16
06-27-2024 13:16
Be sure your GPS in the Fit Bit is #1 turned on and see if that helps if not #2 tell the FitBit to use your phone GPS instead of it's internal GPS.
06-27-2024 21:59
06-27-2024 21:59
Best Answer06-28-2024 03:34
06-28-2024 03:34
@SunsetRunner How many steps are you waking up with? It's not uncommon for me to get maybe 10-50 steps throughout the night as a I toss and turn.
06-28-2024 06:22
06-28-2024 06:22
Best Answer06-28-2024 07:31
06-28-2024 07:31
@SunsetRunner Sounds like you must toss and turn or maybe your watch isn't strapped on tight enough so it's moving around a lot at night.
06-28-2024 10:15
06-28-2024 10:15
Best Answer08-11-2024 14:19
08-11-2024 14:19
I have the same issue another area which I don’t understand is the map. It only tracks half of my walk I do daily. Sadly the device I feel was not ready for consumer use.
