03-09-2025
18:49
09:12
LizzyFitbit
03-09-2025
18:49
09:12
LizzyFitbit
2025 March daylight saving time my charge 6 is showing incorrect values for hours to move and sleep goals. No matter how many times I enter the correct number into my goals the app will not save them
Moderator edit - updated subject for clarity
03-10-2025
03:40
14:28
MarioSFitbit
03-10-2025
03:40
14:28
MarioSFitbit
good morning, I had the same issue yesterday and tried a number of times to change the hours to more with no luck. The app finally updated to the correct time a minute ago. I believe that the Fitbit app time was delayed due to the time change. There’s a glitch. Hopefully your App will update soon.
Have a great day🙂
Moderator edit - Merged messages and formatting
Hello @BethHessdorfer
Fitbit doesn't handle the twice a year time change very well. The Sunday after the time change is a mess. We recommend that you don't try to make any changes until Monday. Often, the time related issues fix themselves on Monday after the time change.
Hello @Catdogg
Have you had a chance to restart your Charge 6 since the time change? If not, give that a try and see if that allows you to fix your hours to move.
Thanks everyone! my issues were resolved this morning without me doing anything else. I just find it irritating that twice a year we go through this problem with our Fitbits in addition to all the other issues the time change causes.
I have restarted my Charge 6 yesterday but nothing changed until this morning and then started changing again for the hours to move. App was set for 9 am to 6 pm and once closed it was showing 10 am to 7 pm. It now shows the correct times again.
Hopefully it is now fixed
Hello @BethHessdorfer & @Catdogg
Thanks for confirming that your Fitbits are now back to tracking correctly.
Hi all
here in NZ daylight savings ended and now I am experiencing the same issues with my step hours snd sleep schedule (at the moment I am supposedly to go to bed at 7.30pm 😎)
can anyone gives suggestions at what to do! This is frustrating al
Best Answer@KiwiF1 Unfortunately theres nothing for you to do to correct it today. It should go back to normal by Monday. Its a well known glitch thats been happening for years that the first day of the time change the FitBit is out of balance.
Yeah, this seems to be a recurring glitch every time daylight saving hits. I’ve noticed the same thing — goals get stuck or display incorrectly until the app syncs up fully a day later. Restarting the Charge 6 and letting the app refresh usually helps, but honestly Fitbit really needs to improve how their system handles the time shift so we don’t deal with this twice a year. For a quick resource on how to manage similar sync or reset issues, you can click here . Hopefully Fitbit will push a patch in a future update.
