09-20-2024
00:40
15:21
AndreaFitbit
09-20-2024
00:40
15:21
AndreaFitbit
I now have my Charge 6 since 2 month and I am experiencing that the Charge 6 no longer synchronizes reliably. I constantly have to restart my phone (Galaxy A34) and even then a third of the measurement (sleep or training duration) is often missing. It seems I'm not the only one who expirience this issue, so when this will be fixed?
Moderator Edit: Clarified subject.
09-20-2024 14:36
09-20-2024 14:36
Hello @meoda
There have been issues on the Fitbit side that affected data syncing & data discrepancies. One of the issues appears to have been fixed. I'm not sure if there are still other issues that are being fixed that impact syncing between Fitbit devices and the app.
Hopefully, you'll start seeing better syncing between your Charge 6 and the Fitbit app, if not now, then soon.
09-20-2024 15:28
09-20-2024 15:28
Welcome to the Fitbit Community, @meoda. I'm sorry to hear that your Charge 6 is no longer syncing reliably. Thanks for letting us know that you have to constantly restart your phone. I'll be glad to assist.
As @RiekoC mentioned, there have been some syncing issues lately but our team is aware and working on fixing this situation.
You can always check help article: Why won't my Fitbit device sync?
09-21-2024 00:54
09-21-2024 00:54
I don't unpair or reset anything. Initially, I initiate the phone restarting and immediately followed by the restart of my Fitbit Charge 6. This procedure typically resolves the sync issue. It is necessary to perform this procedure each time it fails to synchronize. It seems to be effective for me.
09-27-2024 12:07
09-27-2024 12:07
And I was tryna have an upgrade from my pixel to the charge 6 but hearing this is scary
09-28-2024 03:25
09-28-2024 03:25
Same here. But is this your first hit watch? Or you been done used many others? Cause I only had an upgrade to the new charge 6 for 1 month now and I can tell the sleep timer don’t start counting when it’s my sleep time and also doesn’t synchronizes reliably. Please text me
09-29-2024
07:35
16:37
AndreaFitbit
09-29-2024
07:35
16:37
AndreaFitbit
Thanks ,
believe me I checked "Why won't my Fitbit device sync?" a couple of times but this doesn't solve the issue at all. Nevertheless since 3 days the auto sync works again (for whatever reason) but measurements are not 100% correct (like training counter), but for the moment I can live with that. But for me it’s also clear that these issues never happened with Charge 4 or charge 5, so it looks pretty much as a charge 6 problem.
Rgds Peter
Hi @Lynn_moore,
nope, not first time, I used the whole charge series since charge 2. Regarding sleep timer, good point, I also wonder why sometimes the sleep time is counted correctly and sometimes (not often) is not.
Thanks
09-30-2024 05:51
09-30-2024 05:51
@meoda @Do text me privately thanks 🙏
09-30-2024 06:37
09-30-2024 06:37
Hi Lynn_moore, all good on your side? All the best Peter
