04-15-2026
04:18
04:50
04-15-2026
04:18
04:50
My Charge 6 has not been tracking my sleep data for a while. Thought maybe it was a fluke, but it's been more than a week.
Best Answer04-15-2026 04:56
04-15-2026 04:56
Hi there, @fatjeff. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Charge 6 is not tracking your sleep data for a while. I understand your concern, I will do my best to help you with this!
To better assist you, would you mind confirming if your sleep data is only missing on your Charge 6, but showing up in the Fitbit app or vice versa? If this describes your issue, I'd recommend the following:
- Force close the Fitbit app
- Restart your Charge 6
- Reopen the Fitbit app and allow your Charge 6 to sync
However, if your Charge 6 and Fitbit app are not showing your data, I recommend considering the following in order to get sleep stages:
Best Answer04-15-2026 05:08
04-15-2026 05:08
It doesn't show up either place and it was working fine until a week ago.
It started recording very short times and, most nights, nothing at all.
Have not changed how I wear the band nor anything in the app.
Best Answer04-15-2026 05:50
04-15-2026 05:50
@fatjeff Thanks for getting back and for the update.
To better assist you, I suggest reaching out to our Support Team who will be able to take a closer look into this issue and provide further help. This form is only meant for you to use. Click here to get access to it.
Best Answer04-15-2026 19:12
04-15-2026 19:12
I put up with sleep data not being recorded for a long time. After switching from iPhone to Android mobile, every function worked normally so it's clear that it was an iOS software bug.
Best Answer04-21-2026 09:22
04-21-2026 09:22
I woke up early this morning and my sleep data was recorded on both the device and the app. I went back to sleep for a couple of hours more and when I woke up, all of my sleep data has disappeared from the app. It is showing on the Charge 6. I have restarted my device and every installed the app. I have done every step listed that I can find and all of my sleep data including historical data is just gone from the app. What do I do?
