10-26-2025
01:09
07:31
MarioSFitbit
10-26-2025
01:09
07:31
MarioSFitbit
Hello, I have something very similar but mine started on Friday. What is the 3 times push thing? I can't get mine disconnected from bluetooth to try the reset either and fitbit doesn't appear to be charging but says its 41%. I wonder if there is a wider issue. Nothing on my fitbit is updating at all - steps and calories are as if I haven't got the device on.
Moderator edit - updated subject for clarity
Best Answer10-26-2025 01:23
10-26-2025 01:23
Hello, update - I have just restarted the actual fit bit. From clock screen keep swiping down (not up) until you get to Settings the from there select restart device - think it was the last option on the list once I worked out how to select it. Have now found the button on the charger too.
10-26-2025 17:37
10-26-2025 17:37
Hello @AliMF it is the button on the charger that you press 3 times.
Are you able to sync?
Things to try
Iv Elis moved your post to its own thread to keep confusion down
