11-12-2024
14:10
14:03
ManuFitbit
11-12-2024
14:10
14:03
ManuFitbit
After swimming I am unable to stop the timer and the watch does not respond to a double tap. Even if I remove it and dry the watch and my wrist. I have to wait until I get home and plug the watch in to get the timer to stop and therefore my exercise stats are incorrect.
How can I fix this?
Moderator edit: clarified subject.
11-13-2024 05:30
11-13-2024 05:30
Hi there @LucindaEC! Welcome to the Fitbit Community!
Thank you so much for informing us about this situation and for all your efforts.
I suggest you try to restart your Charge 6 with the charging cable:
Make sure the "MobileTrack" feature is not turned on in the Fitbit app. MobileTrack is a Fitbit feature that uses your phone's sensors to count steps when you don't have your Fitbit with you. Steps recorded on your phone may overwrite those recorded on your Charge 6.
Here's how to turn this feature off:
Best Answer11-13-2024 08:02
11-13-2024 08:02
Thanks for coming back to me.
I've tried restarting the Fitbit but the same thing keeps happening. I even set the timer and put the watch under a tap and the same thing happens. When wet, with the timer running, the watch does not respond to a 'firm double tap' nor does the side button. It only does so, once the watch is plugged in which can sometimes be 30+ mins once I've finished my swim. .
With regards to the Mobile Track, it is on. I don't really want to turn it off as the message says that the Fitbit will not receive data from the phone and I thought that was the purpose of it.
Best Answer11-14-2024 08:40
11-14-2024 08:40
Hi @LucindaEC! Thank you for your answer.
Do you turn the swim mode on before swimming?
To turn on the water lock, swipe down from the clock screen tap > Water Lock > firmly tap your screen twice. To turn off water lock, firmly double-tap the middle of the screen with your finger. If you don't see "Unlocked" appear on screen, try tapping harder. Turning off this feature uses the accelerometer in your device, which takes more force to activate.
You could try to set up your device as new too.
Best Answer11-28-2024 08:15
11-28-2024 08:15
Hi Moderator,
I was directed here from the Fitbit support page for the same issue. My Fitbit Charge 6 is unresponsive after doing a swimming exercise with the swimming workout function on. This device is only 6 months old and I tried your troubleshooting tips, to no avail. I can feel the haptics when I charge the device but the screen is completely dark. I purchased the Fitbit Charge 6 thinking it would be better for tracking performance for water sports but it doesn’t seem to work as I’ve had the same issue with an Inspire 3 back in April 2024. please help. I believe this can still be covered under warranty.
Best Answer11-28-2024 08:50
11-28-2024 08:50
Hi there @sprom29! A warm welcome to the Fitbit Community!
Thank you so much for reporting that you're having the same situation too and for all your efforts.
Since you have tried the steps and your Charge 6 still doesn't work, I need more information from you, which is best shared privately. I am sharing a link to a form for you to fill out here.
This form is for you only, so let me know when you have completed it.
11-28-2024 11:51
11-28-2024 11:51
Sorry for the delayed response. I can now get it to work if I take the watch off my wrist and put it on a hard/more steady surface. It still does not respond on my wrist.
Best Answer06-05-2025 09:48
06-05-2025 09:48
Were you ever able to get this fixed? Due to circumstances beyond my control, I have only swum once since I got my new Charge 6, and I had the same problem. I wanted to practice using the screen lock when I wasn't swimming to see if I could get better at it. When I did, it took me almost 5 minutes to get it to respond. I find it hard to believe this is normal. I am also surprised to see so little discussion on this topic which tells me it must work properly for most people. I am trying to get this resolved before it's out of warranty, although it sounds like the warranty resolution process is not user friendly either. Hope you can help. Thanks in advance.
06-06-2025 05:51
06-06-2025 05:51
Hi, basically I found that if I took the watch off and placed it on a hard surface (e.g. the locker bench), and tapped it, it unlocked. Though still can take a couple of goes. Basically, tapping it whilst it was still on my wrist wasn't sturdy enough.
06-23-2025 19:13
06-23-2025 19:13
I've had the same thing happen to me. Just used the Swim lock for the first time for doing laps, once finished double tapped and nothing happened. Repeated the process a number of times, nothing. Got home, followed all your instructions and still nothing my fitbit is completely dead, even the side button doesn't 'click'
When i go into the app on my phone its just stick on looking for the device and shows the same battery percentage as it did yesterday. Can you please assist with further options on how to get my fitbit back up and running.
Best Answer07-01-2025 11:31
07-01-2025 11:31
I need help with this also. I just bought this 6 thinking it was best for swimming.
Best Answer07-01-2025 12:57
07-01-2025 12:57
Best Answer07-05-2025 20:54
07-05-2025 20:54
If I whack the Fitbit really hard twice with two fingers it most of the times comes out of lock position. That’s all I’ve got so far, sorry.
Best Answer07-08-2025 02:05
07-08-2025 02:05
My wife used Chage 6 when swimming in the sea, and it stopped working after a dozen of swims. The screen turned black, and the reset with the cable button didn't help. We've bought a new watch but the old one was sitting in the box. One year later we checked the watch, and the screen appeared working, probably the watch wasn't totally water resistant, got flooded, and it took really long time for it to dry. Unfortunately other than double tap no other interraction with the watch was possible. It looked like the touch screen got corroded with the salty water and stopped working forever. So we keep it as a backup watch--in case the new one gets broken--because it can still count steps, heart load and sleep, does show time and can connect to the phone, but it's impossible to start any activity on it.
So my advise is you put aside your dead watch for a long time like weeks, then check back and maybe you find it resurrecting, and maybe you will be luckier than us so your touch screen will recover, too.
10-02-2025 01:55
10-02-2025 01:55
I have tried all this and still nothing. Charge6 is dead. 4 months old
What next?
Best Answer10-02-2025 04:37
10-02-2025 04:37
Return it to the seller. It was easy in our case, because we bought ours on Amazon. 3 out of 5 were returned and refunded.
Best Answer10-03-2025 14:41
10-03-2025 14:41
Hello @ChristinePey
Since your Charge 6 is less than a year old, you should contact Support (<-- click). Complete the prompt in Step 1. Select Continue in Step 2 (ignore Resources) to get to Step 3, which has the contact options.
