Hello @Keshabdr! It’s great to hear from you!
Thank you for letting us know that your Charge 6 is not charging.
Did you try to restart your Charge 6? If you haven't restarted it, try these steps:
After cleaning the contacts and performing the restart connect it to the charging cable on a computer and leave it for a few minutes to check if it charges and reacts.
Hi @Keshabdr! Thanks for try all the suggested steps.
Thank you so much @Stroller7 I appreciate your help.
Since you've tried all the available solutions for this type of problem, my best advice from here is to contact technical support. They have the most appropriate resources to help you more thoroughly.
