11-12-2024
16:38
09:18
ManuFitbit
11-12-2024
16:38
09:18
ManuFitbit
I just got the charge 6 Fitbit. I am able to see my sleep stages and I got 8 hours of sleep but I don’t see the sleep score. Is there a bug?
Moderator edit: clarified subject.
A warm welcome to the forums @Kverbarg.
Thank you for sharing the inquiry regarding Charge 6.
Please, keep in mind you must see sleep stages in order to see a sleep score. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
If you see sleep stages but don’t see a sleep score, please note that it may take a few minutes for your sleep score to appear. In addition, for better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually and make sure to keep the Fitbit app and the devices' firmware updated to the latest version available.
The Charge 6 may need some days to collect some information (particularly regarding to heart rate) and provide sleep score, sleep stages and other data. Make sure that you've also tried the restart procedure described here and check if you continue to experience the same difficulty.
