10-11-2025
08:22
12:44
DavidFitbit
10-11-2025
08:22
12:44
DavidFitbit
My Charge 6 has stopped logging sleep. Any suggestions?
Best AnswerI was getting nothing. A few days ago, I went into permissions on my android and entered or re-entered " Body Sensors" as a permission for the FitBit app. That may be what fixed it, although the positive effect was delayed by two days if so.
Hi @Stuckonone, thanks for stopping by, I hope you're doing well.
Let's find out the reason why you are not receiving sleep logs and what can be done to get them back.
If you received a sleep log, but it only includes your sleep pattern, it may be due to some possible causes. Too few sleep hours or device's position on the wrist are some. See "What should I know about Fitbit sleep stages? > Why aren’t my sleep stages showing up today?" for more details about.
If you haven't received any sleep log at all, perhaps it is because your device is not syncing. For troubleshooting, refer to Why won't my Fitbit device sync?
Best AnswerHello @Stuckonone
Are you also having problems with heart rate tracking? Do you see a green light on the back of your Charge 6? The green light is the optical heart rate sensor and it's used for sleep tracking.
If you don't see the green light, the first thing to check is that Heart rate is turned on in the Settings tile of your Charge 6
Best AnswerI got it going again. I am not sure what I did.
